setting up my hitachi 32ld6600 tv
4 posts / 0 new
beck118
cannot get my tv to pick up my cable decoder on ext-5 on startup
Check your hookup cable or
Check your hookup cable or try another input.  A little more info as to what type of equipment you are trying to hook up may help as well.
beck118
Larry Dillon said: Check your
Larry Dillon said: Check your hookup cable or try another input.  A little more info as to what type of equipment you are trying to hook up may help as well.
when i  connect my hitachi tv to a virgin v+ box through a hdmi lead which is sourse ext-5 on the tv its ok but when i turn the tv back on i have to go through all the sourses ie tv/ext-1 / ext-2 / ext-3 / ext-4 / ext-4b / ext-5 is there any way i can set the tv to find ext-5 straight away
Do you unplug ther TV set or
Do you unplug ther TV set or remove power from the TV set when you turn off the power?  Any set I know of stays on the input that is on the set when the set is turned off and back on again.  It would only go back to default if the power went out.  If the set is new I would have a tech take a look at it,
