The VHS antenna port for our TV broke. It came completely out of the TV. We were able to put it back in but the screen is fuzzy now. Does anyone know how to fix this or do I have to take it to a repairman?
Thanks for your help.
Copyright © 2020
If you have no electronic experience, you would be best to call in a tech, If you are handy and know about safety with TV sets, take the unit apart and see if the complete assembly is one part, and see if you find a Sony part number on it then go to http://www.partstore.com or you can call them at 1-800-925-PART and ask them to look up the antenna input assembly and how much it will cost you. as you can most likely replace the entire piece. Good Luck and let us know how you make out with this repair.
