samsung hcn4226w B+ 80-90volts
4 posts / 0 new
ace electronics
b+ gets to like 80 90 volts then shuts down,,,
anything common with this model,,,,I ordered the str-x6456 regulator but its just a shot in the dark,,,all of the fuses look good and there dosnt seem to be any shorts,,,just wondering thanks
That is probably your problem
That is probably your problem, I had two of those IC's go bad so far with 27" TV sets. You also could have a couple of bad capacitors in the sweep power supply.  Good Luck and let us know how you made out with this repair.
ace electronics
yea this is my first shot,,
yea this is my first shot,,,thanks ill let you no how it works
kazkillinger
what happened here did he fix
what happened here did he fix it ? I just bought one of these and am having the same issue!!!!
