Magnavox 42 inch plasma turns on and turns back off?
7 posts / 0 new
Klokwork
...I fell aslepp in front of the tv and when I woke up there was no picture but the little blue light was still on. The tv wouldn't shut off but there was no picture ( when it's on there is a blue light in the front when it's off there is a red light) I unplugged it and plugged it back in. I pushed the power button, it clicked on I saw the channel number for a second then it clicked again and there is no picture. The blue light is on but no response.....please tell me what I should do? Thanks!    model # 42MF230A - 37   Serial # AE1B0545000069
Klokwork
..thanks. Can you tell me
..thanks. Can you tell me more about the SSB Board and how much that might cost to replace?
MOtvGuy
Those boards run in the
Those boards run in the neighborhood of $350-450 + the labor to install.  You'll probably be looking to spend at least $500 to fix that set.
Klokwork
....please tell me it could
....please tell me it could be something else?
videodoktor
It may need to have replaced
It may need to have replaced the scaler board
Klokwork
...Can you tell me more about
...Can you tell me more about what a scaler bar is or looks like? I took the back off the T.V. and I have been turning it on and off to get a look at what is going on WILL someone tell me what I should be looking for back here? I heard it might simply be a blown fuse, so I had them all taken out and they tested good. There are 3 small green lights that come on when I power it up and two of them click off while the one stays on. They sre relay switch lights....at the same time a red light comes on .....this is something right?
Way Low Tech
how do i change the closed
how do i change the closed captioning on my 42 inch plasma magnavox ?
