I own a Mitsubishi 1080 Big Screen TV. When I connect the HDTV the HDTV channels come in perfect, but the other channels are mostly a green color. I can adjust the color to a certain degree, but I can't get the green gone. How can I fix this problem?
Also, when the HDTV is not connected the picture is perfect on all channels. The green color only comes in when I have the HDTV connected and watching HDTV channels.
Help
Without knowing the model number I'm going to take a stab at it and call a bad DM board.
Thats what it is a bad DM board, Good call.
What is a DM Board and where can I get another one?
Could I install it myself?
You will need to get the service manual and locate the board and how to take it out. But we still need need to get the model number to make sure your set has a DM board.
OK--I will get the model # ASAP and POST it.
Thank you for your help.
Here is the model number --sorry it took so long. # VS50805
The model you listed can be downloaded from HERE. I have exact discription and directions on how to repair the DM board if you want it. it has picture also. I will need your e-mail addy and will forward it to you.
