Toshiba 50H12 Green Screen
dlboggan
Greetings,
I too have begun to experience a total green screen.  Menus are normal color.  But all signal inputs show a green screen.  This makes me believe that there is a gun problem in the system.   I have attempted to look at all menus to see what options are available to resolve this issue.  Model is Toshiba 50H12 rear projection screen.  Any advice would be greatly appreciated.
Best Regards,
David Boggan
I would tend to believe that
I would tend to believe that there is a video processing problem with your sey my friend.  If it was a crt drive problem, even the menus would be green unless there are two differant CRT drive or outputs to drive the CRTs.  You will need to get a service manual and see where the menus are injected to the crt drives and where the composite vidie comes into play.  Most likely a problem in an amp or sitching IC.  Good Luck and let us know if you found anything with this set.
