Sounds like the TV set is starting up and then going into a shutdown condition. The set could be going into OCP- Over Current Protection, OVP- Over voltage protection, or One of the sweeps is failing and putting the set into H-stop or V stop. The LED front panel light will most likely be able to direct you to the location of your fault on your TV set Look at the light and count the number of times it blinks and follow this chart:
Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
One blink - not used for the self-diagnosis
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the Cboard, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402.
Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator. Make sure the part number is -12 or -13.
If you have no solid state troubleshooting skills or do not have the equipment to do these repairs, play it safe and call in a pro to assist you in this repair. good Luck and please keep us informed of the progress of this repair.
hi larry the led light does not blink it stays green all the time.with no remote or front panel function,tv picture trys comming on but its like it got no video and no sound also. hope this help you better.
