Question tuner/gemstar
Silva
Hi,Guys have 2 questions. can i install a tuner or Gemstar from same chassi# on other ctc 203 chassi ?
If it is the same chassis and
If it is the same chassis and part number sure.  if it is the same chassis but differant part numbers, no Most likely it will not work as there may be differant firmware in the micro to run the differant part numbers.
