Hi. I have a Hitachi 53" rear projection tv. Today, when my son turned it on, there was a glitch with the screen. There is a "fold", for lack of a better word, at the top, and the colors are all screwed up! I have 2 pictures. This is what I am dealing with.
here is another one
I have the pictures much bigger...if you have any ideas, or want to see the bigger pics...email me!! [email protected]
Thanks!!
I talked to someone who said that I may need to re-align the green projector. That seems to be the one that is out of whack. Does anyone know how to do that?? Please help...I'm getting desperate!!!
By the way...it is an Hitachi 53FDX20B.
Thanks!
Looks like one of your convergence IC's has failed.
Dear [email protected]:
I have had a problem much like yours. My blue convergence screen had a similar problem. Check the components in the right hand corner of the set's PC board for burnt or over - heated components. Mine had an over-heated 1,5 ohm 2 watt resistor. Replace or repair as necessary. Then, resolder all the connections on the convergence I.C. s . This has fixed my problem - I hope it will help you. If the convergence I.C.s need to be replaced you'll be most of the way there anyway after this repair. Best of luck, stay safe!
[email protected]
