RCA F36650 HOW DO I CENTER THE PICTURE
ooscarace
RCA 36 INCH PIP ENTERTAINMENT SERIES  [2002 ]  GREAT PICTURE BUT ALL OF SUDDEN THE WHOLE PICTURE SHIFTED TO THE LEFT AND NOW I HAVE A BLACK BAR ON THE RIGHT SIDE IN THE MENU I CAN ADJUST THE TILT BUT THERE IS NO ADJUSTMENT FOR THE CETERING OF THE PICTURE PLEASE HELP THANKS.
A Hi Voltage capacitor went
A Hi Voltage capacitor went bad inside your TV set.  This is a critical componet and has to be replace with the proper value. This is not an adjustment.  This is a repair job that should only be preformed by a trained tech.   If you did want to try to repair this set, you would first need a service manual and an ESR capacitor meter to find the defective componet.  Good Luck and let us know how you made out with this repair.
