my 2002 rca p46924's picture is bowed on top and bottom and sides steched out.....also when i goto adjust there is no green adjustment, the blue is blue, and the red is orange.....please help
Green convergence is stationary because the red and the blue adust into the green. does the Picture look like it is 3-D on the sides? if it does, the convergence IC's need to be replaced. if you have soldering on solid state printed circuit boards, you may be able to replace these IC's yourself. But you will first need the service manual, and a mutimeter and know how to read a service manual and use a multi-meter. If you do not, Play it safe and call in a pro to assist you in this repair. good Luck, and let us know how you made out with this repair.
