Sylvania TV will not turn on
Troys
I've got a 23" Sylvania TV that is just over 1 year old and only used at night for a couple hours.  The unit will no longer turn on, I've unplugged and tried different outlets with no luck.  Has anyone got a solution to this problem?  It's model number is SST4245.  Thanks
Troys
I've replaced the fuse in the
I've replaced the fuse in the TV and when plugged in the fuse blow again.  Is there something else that I can check out?
