PLEASE EVERYBODY THAT POST HELP IN THIS SITE NEED TO LOOK ON THE BACK OF YOUR SETS AND GET, BRAND, MODLE#, AND CHASSIS#, SO WE CAN HELP EACH OTHER WITHOUT GUESSING.
My sony 70 grand wega turns itself off and the red led blinks in increments ofsix times. the manuel only deals with three blinks, any help is appreciated.
hi and first thanks for your time ... odd request, ive got a av48wp30 jcv projo, a 105 chassis, im looking for the exact dimensions for the mirror for this tv. any help at all would be greatly appreciated . p.s. already know part # price where to purchase, thats why id like to go to glass shop and have cut instead .thanks again
Sorry to have to tell you this but a regular mirror will not work correctly. The mirror in the projection set has the mirror surface on the outside or the surface of the glass. Unless you can get this type of mirror you will have all sorts of reflection problems. I have replaced some mirrors with a mylar replacement. you can measure the size of this mirror by measuring the brackets that holds the mirror in place. Good luck and let us know how you make out with this repair.
The IC's you are looking for are available HERE They are IC8C01 and IC8C02. They are the STK392-570, and just for giggles the Mitsubishi part number is 267P150010. You really should replace both IC's at one. Also make sure you use plenty of heat sink compound on the back of the new IC's before you install them. Good Luck and let us know how you make out with this repair.
dtroise said: My sony 70 grand wega turns itself off and the red led blinks in increments ofsix times. the manuel only deals with three blinks, any help is appreciated. Donald Troise
I believe if I rember right one of the cooling fans is not running (memory bad sometimes)
This is great advice Silva. In fact, I'm making this thread sticky so everyone gets to read it.
Donald Troise
Ok I found the mod. # but where is the chassiss # on a LCD?
Per Silvia's request so we can get more help.
Toshiba 50H71 Rear Projection TV
http://www.techlore.com/images/home/b..., sizingMethod='image'); width: 16px; cursor: hand; height: 16px"> JWhite post
SR# 58600309
Ch#TAC0162
Thanks Silvia! :)
I have a mitsubishi WS55807 Cannot find the chassis # I have searched this and other forums and still cannot find the help I need.
1. I have convergence problem horizontal bow tie effect.
If someobe could help with the IC # I think it is stk 392-570 ic and where to order.
the location on the motherboard, i can re solder if necessary as I build and repair computers.
drsims2
