hello, i have a sony M# kp-51ws510 2 years old been just fine, today the colors look like you need to wear 3-d glasses to watch it, the red and blue lines are off about an inch, anyway any help or advise would be greatly appreciated thnx tazor torquino
You have the typical convergence fault that hapens to almost, if not every tube type rear projection set made. They are STK type IC's. If you have any solid state printed circuit board repair experience, then you can get a service manual and unsolder the old IC's and replace them with the original manufacturers parts, as the inexpensive replacement IC's will not hol up. If you do not have any solid state repair experience, play it safe and call in a local servicer to assist you in this repair. Good Luck, and let us know how you made out , or if you need any more assistance.
thnx so much i will look into finding the parts thnx again
Go to http://www.partstore.com You will find everything you need. if not call the 800 number.
