HI can anyone suggest the fix for a dvd player not playing sound.My two year old decided to play and messed everything up. I've got the picture back but I can't get any sound.And yes you've guest it I have lost the instructions. Player is a PLU 2 DVD 650V/653V
- Switch your amplifier to the player's analog outputs.
- Clean the disc.
- Check that all interconnects are firmly inserted.
- Clean the plugs/terminals.
- Check the audio connections.
- Connect to any set of inputs except phono.
- Press (play) to exit the pause mode.
- Check that the volume is turned up ,that the speakers are on, the input function set correctly, etc.
This is the only thing I could find on a model close to yours. Good Luck and let us know if you find soimething.
Thanks Larry unfortunately none of the above has cured it.
Graham R
