I just got this tv to fix and the fuse was blown inside. I replaced the fuse and all it will do is turn on with no pic or sound and then in a few seconds turn back off. Could this be a pic tube or what?
Are you a Tech? Or you want to be a tech? LOL! Do you have a volt ohm meter? Do you have a service manual for this set? Do you have a esr type capacitor checker?. If you do not, get one and start out by checking most of the smaller and larger capacitors in the main power supply. This set is common for this problem with bad capacitors. Good luck And please let us know howmyou made out with thises repairs.
