Everytime I turn my phillips television on...it magically turns off. If I change the channel the power will turn back on and the screeen is refreshed. It wil turn off again 20 minutes into a show...an hour...or even right when you turn it on. Is it possible to fix this myself or do I need a tv tech? Thank you
Nancy, if you have no TV rePair experience, please play it safe and call out a tech to assist you in this repair. A TV set is not a place to be experiementing around with, as you could light up yourself brighter then Rockafeller Center, Midtown NY. And Give yourself a permanent Perm! Good Luck, and please keep us informed of this repair, as maybe it will help someone else.
