I have a 32" Philips TV that is 3 years old. Every other time I use the TV the sound delays coming on. Picture is perfect and everything else works great. I can change every menu option possible and no effect. Sometimes the sound just takes 10-15 minutes to "warm-up". Any thoughts?
Most likly a filter capacitor in the power supply circuit, that feeds the b+ to the sound processor circuit, and/or the audio output iC's. if you have no TV repair experience, please do not experiment with this TV set and call in a pro to assist you as this should not be that expensive to repair. Good luck and let us know how you made out.
