Cable Installation Problem
3 posts / 0 new
Romanson
I attempted to install cable to a TV in our kitchen. I have cable in several other rooms of the house which I have installed myself. This time, however, although I have installed it, I cannot get cable stations on the TV. In fact it goes to channel 91 right away. I have tried two different cables, changing the cable to a connector to the cable box in the attic that I know functions for another room, setting the TV from the menu mode, and setting it for cable.
You cannot just set the menu
You cannot just set the menu mode to cable, you must also do a channel search on the set, then it should work fine.  good Luck and please let us know how you made out.
Romanson
Larry Dillon said: You cannot
Larry Dillon said: You cannot just set the menu mode to cable, you must also do a channel search on the set, then it should work fine.  good Luck and please let us know how you made out.
Thank you so much for your help.It worked! We are now functional!
