Phillips Magnavox TS2744C106 DEAD
4 posts / 0 new
tmanqz
 My Tv made a cracking noise then a smoke smell and died.
(Phillips Magnavox TS2744C106)
I removed the back cover to investigate and discharged the tube for safety.
I noticed a burned up capacitor(C506) on the board.
Im searching for a parts manuel/schematic so I can get a OEM number on this capacitor so I can replace it and see what happens, I suspect the flyback may the root of this problem.  I did locate a flyback at www.Partstore.com but no service manuel or capacitor.
I would much appreciate any info on locating a schematic or service manuel for this tv. It worked fantastic up until this happened.
Bright Apollo
go to tritronics.com they can
go to tritronics.com they can probably look up the part number for you.
There is a downloadable  PDF
There is a downloadable  PDF service manual available here.  If you want I will send the Email to you and You can send me a copy if you need further assistance with this set.  Good Luck, and please keep us posted.
tmanqz
Thank you for your help I
Thank you for your help I will let you know how it turns out.
