Hi, i purchased an Insignia tv a month ago, and recently the red on the screen started to flicker on and off, and now every color seems to slowly burn out, until the screen is black. Is there any way to manually fix this?
No Im sorry to inform you that your problem is going to most likly going to be in the drive panel. You should contact the servicer located in your owners manual, or go back to the store where you purchaced the set and see who they would recommend for the repair. This si not a job for the do it your selfer. Good Luck and please keep us informed of your progress.
