I've got a Toshiba 36ZP38 and the picture has suddenly become posterized like it has been through Paintshop or similar. anyone have any ideas how to fix it or what has caused it?
I have a 32zp38b and with an intermitant picture fault. Two days ago the red seemed to disappear(Sounds similar to paulr) Today it went all zig zagy after a while of being left on it comes back to life and all is well. Any ideas????
paulr And loado, It sounds like you have a common fault with these toshiba TV sets. its a fault on whats called the Hyper module. im told these madules are very expensive, but there are several small surface mounted capacitors that go bad on these boards. they are 10 MFD @16volts. They are under the sheild on the module. You should if you have any soldering or TV repair experience, be very carefull taking off the sheild as it is easy to crack the board. Good Luck and let us know how you made out.
Hi
Thanks Larry - Will give it a go and come back to you. Cheers
