Sony TV/Standby Timer Blinking Codes
42 posts / 0 new
KG
Hi!
We have a Sony that is eight years old,the remote was broken not to long a go.
Can the instructions be accessed by a Universal Remote?
The TV keeps blinking & we can't stop it,just found this site & instructions to find out what is wrong with it.
It's a KV-27????,can't get in the back to see the exact model.
Please can anyone help,we are getting headaches & can't watch TV & we so much want to watch the CMA'S tonight.
Thank You!
You should read this.  If you
You should read this.  If you are not a tech or have TV repair experience, im sorry to say there is not alot that can be done to these sets as they are all solid state and have no user replaceable parts inside them.  These type of repairs are repaired down to componet level.  If you want to read more about repairing TVs go Here  or Here .  If you need any more assistance please feel free tio ask.  Good Luck and let us know what had to be done to the set to get it to work.
KG
Hi Mr. Dillion,
Hi Mr. Dillion,
The self-diagnosis function,to find the fault codes,don't know how to retrieve it with a Univeral Remote since we don't the orginial remote.
When the TV is turned on the red light flashes until the TV comes on & is no longer lit.
The light flashes more than indicated in the eight blinks indicated in the instructions.
The TV picture is what keeps flashing.
The TV was working fine until we bought the Universal Remote & that's when all this started happening.
So could it be that the Univeral Remote did something to the TV?
Thank You!
Oh its the screen thats
Oh its the screen thats flashing?  Thid could be a fault in the Kine bias circuit, or maybe a bad picture tube even.
saudiboy
Hey.
Hey.
I've got KDF 60XBR950 and 3 blinks.  Can you tell me what this means, and whether I need to call someone to fix it (and if so, what it should cost, roughly).
Have you opened the lamp door
Have you opened the lamp door recently, or someone opened it and did not close it fully?   This could be the cause of the 3 blink code in these TV sets.  Or perhaps the bulb is not seated correctly, or there is a bad switch on the door assembly.   Good Luck
saudiboy
Larry Dillon said: Have you
Larry Dillon said: Have you opened the lamp door recently, or someone opened it and did not close it fully?   This could be the cause of the 3 blink code in these TV sets.  Or perhaps the bulb is not seated correctly, or there is a bad switch on the door assembly.   Good Luck
Thanks for the response.  I hadn't even heard about these blinking codes.  When I called the shop that sold the set, they told me it was the lamp (I didn't realize that there was a separate indicator for the lamp).  So I bought a lamp and replaced the existing, and of course, this didn't solve the problem.  When I replaced the lamp, I did notice that the plastic face plate that covers the lamp opening looked like someone had stepped on it (it must have been this way when I bought the set - who knows why).  But then again, the set has worked great for two years without anyone having removed the distorted faceplate.  I've re-installed the lamp a couple times.
You are going to need to make
You are going to need to make sure the door is closed properly.  Have you done this yet?
johntorres
I have a sony KDF70XDR950
I have a sony KDF70XDR950 that blinks six times,what does this mean. any help.THANKS
johntorres
Ihave a SONY KDF79XDR950 that
Ihave a SONY KDF79XDR950 that blinks 6 times, Any help you can give , THANKS
6 flashs mean there is a 6
6 flashs mean there is a 6 volt issue, could be a bad G1 board?Should be done only by a trained tech though. Cost too much to play around, you could ruin the set!
Shad Skinner
I have a KV-30HS420 TV will
I have a KV-30HS420 TV will not turn on for more than 2-3 seconds. I get no Pic just sound. Stand by light flashes 7 times.
Dorian
No picture or sound just red
No picture or sound just red power light blinking
Dorian
sony model kp-53s65 red power
sony model kp-53s65 red power light steady blinking with no picture or sound
Is it a steady flash or does
Is it a steady flash or does it pause in between flashes?
Shad Skinner
seven flashes then pause then
seven flashes then pause then seven more flashes
Dorian
standby light is constantly
standby light is constantly flashing and tv does not come on
Tony T.
HI I have a sony kv-36sbr800
HI I have a sony kv-36sbr800 serial # 9014176, I got up this am and found the standby light flashing in patterns of six flashes at a time. No sound or picture. I have tried unplugging the set and it still only will blink six times then pause. What course of action should I take at this time. Thanks.
sorry NO SUCH model number
sorry NO SUCH model number What is the COMPLETE model please???
Tony T.
I'm sorry the number is kv
I'm sorry the number is kv-36xbr800 serial number 9014176 it was early and the coffee had'nt kicked in yet.
Sky0
My sony trinitron tv (KV
My sony trinitron tv (KV-35S45)won't turn on. It's blinking repeatedly in standby/timer mode....It blinks about one blinks per second, how do I fix this problem ?
mamaofboys
hi i have a sony trititon
hi i have a sony trititon serial number 8068277 model number kv-27fs16 and its has the stand by timer blinking 4 times can you help me to find out what the problem is. thanks
DB Vegas
I have a KDS-A602020 and the
I have a KDS-A602020 and the lamp went out. I bought a replacement Philips lamp and have installed it. I bought it with a new housing and everything to avoid having to take bulb portion in and out. Once I replaced the bulb the TV fired up fine but about 1-2 minutes into watching it the picture flashes for a split second and will continually do this after that. I have gone into the settings where they have a
trushaft
Sony KDf 55e2000 blinks 3
Sony KDf 55e2000 blinks 3 times I assume lamp door like last guy.I hope
whaid
hi mr dillon,i have a sony kp
hi mr dillon,i have a sony kp-57ws520 i am getting 9 blinks ,the service manual tells me its the G board i check it out i found D6118 open i did some checks and i think its a 27v zener diode i replace it ,but the realy still does not click could you tell me what i could do or check to start back up this set , or by the way i know my way around the circuit thanks for any help.............
unplug the G board and look
unplug the G board and look up ptscorp.com and call them to see what they charge to overhaul that board. or if you are handy look up that complaint here on this site as there is loads of instructions here on that problem.
Larry Dillon.
rjdinges
I have a Sony KDF-55e2000. I
I have a Sony KDF-55e2000. I was getting the three flashes and could not seem to get tv to work by playing with the lamp cover. I removed the switch which looked like the soldering of the connector had failed. I ordered a new switch however when i had removed the switch, the wires came out of the connector. How can I find the order of the wires to the connector for the new switch? Also, there are only two wires and it is a three prong connector. Is there a wire diagram available?
Geoffers
how do i resolve the single
how do i resolve the single green constant flashing standby light?
Geoffers
sorry didn't give you all the
sorry didn't give you all the info. It's my old ma's tv I guess she's had it two maybe three years - I switched it off by accident this morning so she's had to make do with radio today. I just checked the number and it is a sony bravia kdl-32u300.
Any help gratefully received.
G
Geoffers
Also to clarify, it's the
Also to clarify, it's the green standby light continuous steady blink 1 per secondish, which from the codes I take it to be the data bus is busy.
myfrankie101
We have a KP-53HS10. The
We have a KP-53HS10. The standby light blinks 5 times, then stops for a few seconds, then blinks five times again. All the time, the picture blinks off and on. We have had it repaired 2 times now. They replaced the video board/card (not sure which one they called it), charged us $400.00 and brought it back. It didn't help, it was still doing the same thing. They picked it up again, kept it for two months and then returned it, free of charge. Said it was fixed. It is not fixed! It still blinks 5 times, the picture still blinks on and off and we don't know what to do?
please help!
I realize it is an older model, but its a Sony and we were hoping it was worth putting $400 dollars into it. The tv is in great condition otherwise.
