Subj: Philips TV Model TS2745 C107, SN 13303039, Chassis 27B700-7562
Unit
just quit - as if someone had pulled the plug. Pushing the "ON"
buttion causes it to turn on for about 1 second then off.
Removing
the PC board, looking for visual problems, I found "C506" burnt to a
crisp. On another web site, I say a post that somebody had the
same problem, replaced C506 and it came to life. That post was 2
yrs old and when I tried to contact the person, no answer.
I can't fine out the value of C506 so I can replace. Can you help?
DannyG
Sorry man the models, chassis numbers dont match up to anything I have. Is this a USA model??
Hi Larry. I rechecked the numbers to make sure I typed it correct and I did. It is a USA model.
On
Google, a search of "TS2745" and/or "27B700" does bring up some stuff
as if the numbers are recognized but nothing I can find will show a
schematic. Sometimes the results of the chassis number is "27B7".
DannyG
OK I located a service manual, but it is not a freebe. Its number is 7562. Thats the Philips number and is available at http://www.servicemanual.net as a download for about 24 bucks. Sorry thats the best I can do to assist you. Please let us know how you made out. Good Luck
Larry, thanks for your help. I would rather not buy the Manual, Hah.
Hopefully someone else reading this thread will have access to the manual.
DannyG
