I have a sony wega trinitron kv-27fs13 the picture has started to flicker and sometimes the no signal appears on the screen. I checked the cable conection and noticed the input cable conector on the back of the t.v is loose and spins around. If I take off the back off the t.v. will I be able to tighten it to solve the problem. Thank you Hogan 16
The model you have uses an antenna block assembly that is replaced as a unit.. It should be available at http://wwwpartstore.com Try first the aux. input and make sure you switch the input with the remote. if it still flickers then I would say that the tuner is going bad and you can get one of those on an exchange at http://ptscorp.com. if you have no TV repair experience, i highly advise you to seek out a trained tech to assist you in thios repair. Let us knowq how you made out and Good Luck
