MITSUBISHI BIG SCREEN
3 posts / 0 new
ashlyga
I WAS WATCHING THE FOOTBALL GAME SUN AND IN THE 4TH QUATER THE TV SHUTS OFF. SO I GO TO TURN BACK ON AND THE (GREEN) POWER BUTTON GOES ON THEN OFF IN THE MATTER OF TWO SECONDS NO TV. SO THEN I WENT AND SHUT OFF ALL THE BREAKERS AND TURNED BACK ON AND IT CAME ON FOR LIKE 10 MIN THEN SHUT OFF AGAIN. AND IT HASNT BEEN ON SINCE PLEASE GIVE SOME ADVICE
Try first on any electronics
Try first on any electronics with a standby power suply to unplug unit for at least 12 to 24 hours. If that does not help, you most likly have bad capacitors or a sweep supply problem, and unless you have the ability to test the caps with a checker and the sweep supply with a scope, you really should call a pro in to assist you with this repair. Let us know what you decided to do or if you got it fixed and what it took to get it working. Good Luck
