I have a Symphonic 19TVCR MK III. I am trying to find the proper device code for the TV to synch with Dish Network. Dish Network gave me three device Codes for Symphonic TV. Two of them supposedly work (TV device button flashes 3 times). However, the TV cannot be turned off using the power button, no browsing of channels, etc. I do not have the Symphonic remote. Have you have any suggestions or knowledge about this TV? Perhaps it just isn't compatible with satellite? Thanks for your help.
Try the auto search mode to find the TV set. If you run thru them all and the TV does not respond, then the TV set is not compadable. Nothing can be used other then the original remote, and that can be seen and is available at http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&m1=19TVCR&uid=1157295057408
