My roommate did something to my dvd/vcr while I was at work one day and now when you insert a dvd to play, you get audio, but no video. Also on the display of the unit, it shows the{p}for progessive mode which had never been on the display before.Can't find anything in the manual about any possible way to fix this. Tried unplugging the unit to try and reset it. Also tried to reset with the set up menu, but that is not possible due to not being able to get the video portion to come up. Can anyone help?
You should be able to change the progressive scan output from the DVD player setup menu, but you'll first need to connect the DVD/VCR to the TV using the yellow composite video cable or S-Video connection. That will allow you to see the picture once again.
Once you've changed the output back to interlace, you can reconnect using component video.
