HELP !!!!!
What ever I do, play or record it always tell me there is "NO DISC" on DVD playback or record
Sansui VRDVD4005 DVD VCR recorder combo.
please explain what is wrong.
Thanks in advance.
HELP !!!!! What ever I do, play or record it always tell me there is "NO DISC" on DVD playback or record Sansui VRDVD4005 DVD VCR recorder combo. please explain what is wrong. Thanks in advance.
Sounds like there is a problem with the drive itself. You'll need to take it to a shop, or better yet, replace the unit.
shakys baby said:
i have recently purchased a phillips dvd recorder but can.t tune it to a normal to channel it is on RGB any advise please
By your description, I can't really make out what your problem is. If "can.t tune it to a normal to channel it is on RGB" means that the unit is set to view one of the external inputs, then you should look for an input button somewhere on the unit's remote control or front panel.
I have a question i was transfering a vhs tape to dvd and when i was done i then wanted to tape something so i did i used a different disc and then i went back to transfering then i wanted to see the show i recored on tv and it took along time to load i could hear the disc clicking then after awhile it said on the screen fail and at the top invalid disc what do i do i can't watch what i recorded or record i can't do nothing is it beace i transfered alot of vhs tapes to dvd and something is wrong with the machine, the machine works fine i can still transfer vhs to dvd and record it is just the one disc i don't get it is the disc bad? please help
