GE -TV-Model.# 13GP241 -Will not turn on
10 posts / 0 new
dave9354
I have a GE TV Model #13GP241 (chassis #TX826TB). The set will not turn on with the remote or the push button on the set.It was working fine the day before. What could be the problem? Thank you , Dave.
ozone1
Hi There,Check the outlet for
Hi There,
Check the outlet for power...circuit breaker off in house panal, outlet could be bad, check the TV plug and wire for damage!!! Use a lamp or something to check power at the outlet!!!
ozone1
jolie
The power source is working
The power source is working and the wire is fine.
FlashGordon
I have the same problem in
I have the same problem in the same chassis number. There is AC input to the chassis but there must be a relay that turns the set on and it is not working. I would like to have documentation that supports or denies this.
Modesto RodrÃÂ...
I have the same problem but i
I have the same problem but i don't fine any relay that work with this, if somebody can help me to find a diagram,or other else, is going to be geat.
thanks: Modesto
Modesto RodrÃÂ...
thanks: Modesto
REMOTE#024040
i CANNT GET TO BACK OF Tv to
i CANNT GET TO BACK OF Tv to see model number. It is an older TV. Remote will not now change channals when used. Batteries were changed. any suggestions as to what I can do?
Phyllis Parker
I can't get the sound to work
I can't get the sound to work, there is no sound, How can I get this repaired, where can I get an owners manual?
Phyllis Parker
I can't get the sound to work, how do I get this fixed? Where can I get or download and owners manual and why is this to hard to get an answer for?
Phyllis Parker
