Depending on the kind of receiver it is (single tuner, dual-tuner, etc.), you can normally connect the closest TV with A/V (yellow, red, white) cables, and connect the second TV using the coaxial RF (screw on type) connection.
If you need more specific help, use the "Add images" link above the post to add a digital photo of the back of your receiver and we can tell you specifically which connections to make.
