Help Please Urgent
The Greatest
Help Please Urgent
Hi, I just got a new lg 19" monitor and when I plug it into my computer, it says analog out of range. If I play with the pixals, the "out of range" numbers change. Help
Most likely the display
Most likely the display resolution or refresh rate is beyond the capabilities of the monitor's analog input range. Set the resolution output of the computer to 1280x1024, and make sure the refresh rate (under advanced settings) is set between 60Hz and 75Hz. Screenshots below.
