I have a Sharp Tv remote that was slightly unaligned with the chips inside because it was dropped...so every time i pressed the Flashback butTon a code would be displayed on the upperright of the Tv For Example (SD-331-313)..as i would press the flashback button the color of the screen would keep changing into darker colors.I finally made the remote align with the chips..Now the remote is in its orignal state..I cant get back my origninal colors!!THIS HAS NOTHING TO DO WITH THE COLOR MENU!!
Something wrong with my Color Display!!
Mon, 06/20/2005 - 11:56
#1
If the remote sent out some commands that alter the TVs internal setup, you'll need to have a service guy adjust some parameters in the service menu. You're talking 125 dollars or so for in-home service (less if you can carry it in), so it could be a lot worse.
Watch your remote closely. It may work now, but it could easily start spitting gibberish again.
