rca tv with a concave picture
3 posts / 0 new
maccer
Tried a hard reset for a couple hours with no luck, Its been about a month a my picture hase stayed the same. )( thats the easiest way to discribe the way the picture is. Any info is appreciated. Thanks MACCER
Bright Apollo
this is a pincushion problem.
this is a pincushion problem. caused by either bad connections or a defective pin diode and cap.
Chassis Number would be good
Chassis Number would be good if you want to try to repair it yourself.  That is if you have any soldering and solid state repair experience.
