I have a Mitsubisi model 52531. It has had the dreaded blinking light issue and will not turn on most times. Can you please send the information to [email protected].
Bill, I keep getting this message when I try anf send you some info:Hi. This is the qmail-send program at yahoo.com.
I'm afraid I wasn't able to deliver your message to the following addresses.
This is a permanent error; I've given up. Sorry it didn't work out.
65.54.245.72 does not like recipient.
Remote host said: 550 Requested action not taken: mailbox unavailable
Giving up on 65.54.245.72.
recently bit by the green blinking light after a power outage can you send me the repair instructions and the cap part numbers
Thanks] [email protected]
I know this sounds like a broken record, however, my Mitsubishi WS-65611 is having the same problem everyone else is posting, no power. The green light comes on for a few seconds and goes out. I did the reset button and the menu + device for 5 seconds still the same results. When I hold the two buttons I get the 2 + 2 blinking.
Any advice you could pass along, including diagrams would be greatly appreciated!
Kenny how or where can I send you anything? no e-mail man! What you need to do is check F9A04, and FA905 for continuity. If one is open FIRST REPLACE the convergence IC's then the bad fuses
Mr. Dillon i would like to get a copy of the instructions on how to repair my ws-65513 for the common blinking green light. Please send to [email protected]
Mr. Dillon, I would like to get a copy of the instructions on how to fix my
ws-65513 tv for the common blinking green light. thank you craig
please send to [email protected]
thanks to this site, i was able to repair my brothers Mitsubishi with the green blinking light. That was about 6-8 months ago and it is still going strong, however it started a new problem. Now, periodically when he changes the channel, the V-CHIP Parental lock comes up and asks for a passcode. They have never knowingly set a passcode so they do not know how to get this off. Can you help?
I need help! Our electricicity went out and the Mit. TV was on Model W55511, it was bought about 5 1/2 years ago...big box HDTV set. We have the blinking green light issue. This has happened twice before and the green ligth stopped after about 15-17 hours. Now, it has been over 24 hours. I called the
I have a WS-65513 with a model 934C0670 board. I was able to replace the 4- bulging caps. My problem is I accidently knocked off an inductor in the process. It is on the lower right hand corner location L9B22. I need a replacement part number for this inductor. [email protected]
I have this same problem with my tv. If you still have the info to fix the infamous greenlight problem, would you plase email a copy. Greatly appreciated. [email protected]
Larry, Please email me the repair instructions to [email protected]. My 6 year old Mitsu started this last night. Just shut off while I was watching it.
I Have a WS-65809 and I'm having this exact problem. The TV turns on, the green light comes on and in a few seconds you here a loud click and it turns off.
Larry:
Bill
Larry:
I have model 52531 and have the dreaded blinking green light. The TV does not turn in some times. Plese send the information to [email protected].
Bill
Hi Larry, i have a the same problem model number WD-52725. Can you help me out? Thanks. [email protected]
Larry:
Yahoo must be acting up. Let's try [email protected]..
Thanks]
sorry it is a ws 65909
thanks so much
kevo
Kenny
My email address is [email protected] Any diagrams you send would be great.
Thanks Kenny
Larry
I would like to get instructions to fix Mitsubishi WD 62725. Have same green blinking light problem; email: [email protected]
axar
Hello Larry, can you send me the service manual for the WS65611. Thanks.
Sorry about that. Please send the WS-65611 service manual to [email protected].
Thanks Kenny
cory there is an article here I submitted several months ago called, "Are you locked out" That should do it or e-mail me and I will send it to you!
Got it! I will try this tonight and let you know how it goes. Thanks Again!
I guess folks think i can read minds or i have a secret crystal ball!! I need An E address!!
Larry I have the same problem, blinking green light. Could you send me a copy also on how to fix it? Thanks! [email protected]
tour e-mail did not work man! It came back as undeliverable address or no such addy.
email address is [email protected]. Would you mind giving it another try? Thanks a lot.
Larry could you please send the instructions to [email protected]. I also am a victim of the flashing green light. Thank You
Could I use these instructions to fix my tv?
Please send me the instructions to [email protected]
Thank you in advance for your help.
Larry, I have the same issue, please send instructions,,tks
Larry, I have the same issue my model # is WD-65869 pls send inst to [email protected]
