2603 posts / 0 new
bsmith11
Da Chief said: Super Larry!
Da Chief said: Super Larry! Man does Mits keep you busy just sending out repair info! And I am in the same quandry! LOL! Mine is WD-65833.....infamous blinking green light. Replaced bulb and still does it. Thanks! [email protected]
Replaced the 4 capacitors in my WS 65813 this week for $7 in parts - it turned on - I was surprised and pleased, although Mitsu should be doing a recall on such a wide spread problem IMHO.
Gary Smith
I have a WS55909 with
I have a WS55909 with blinking light. Please send cap replacement infor to [email protected]
larry45211
this is unbelivable blinking
this is unbelivable blinking light help. 5 min on the computer and i think you have my answer. please send cap replacement info to [email protected] i own a ws-65513
Greg B
well i replaced ALL 7 caps on
well i replaced ALL 7 caps on the DM board and nothing..fortunetly it only cost me $50.00 now I guess I need to look at the power supply.. still get a blinking green light at power up
Bladerunner
This is a question for the
This is a question for the advanced repair folks on here for a WD-52525...
1. Replaced critical caps on Power Board. Probed voltage test points - all good. All fuses good.
2. Replaced essential caps on DM and FMT board. had bad caps in various boards.
3. Used USB unplug procedure to check card reader board. Its good.
Power up...
1. Pulled connector from FMT board to get blinking light to go out.
2. Plugged in power. green light goes out after 70 seconds.
3. Plugged FMT power back in.
4. Hit power button on front. Set comes on with normal speaker static.
5. Relays click and I know power going to lamp. Voltage on power board connector (J9 etc) going to light engine board gets correct power
6. I can see dim blue light on screen as lamp starts firing up.
7. After a few seconds it dumps to a steady red status light, no red lamp light. No power light (previously green blinking light). Speakers go out and is expected.
8. Book says a short or DVI cable blah blah blah.
9. Unplugged far right hand top cable (PA) on power board going to light engine (J9) and repeated. Speakers come on and the set does not dump and turn on the red status light.
10. I did find that the J9 (PA) connector power (upper right connector on the power board)does not come up to voltage until the relays kick in (Pins 1 and 2). This does not seem abnormal to me.
- My lamp is about 1 year old (OSRAM), no signs of being blown visually. Looks new
- I checked all cables for cuts etc...all look good.
- All covers on and fans work etc.
- If you "hit the wall" here in your troubleshooting please let me know what else you did to get past this point....or what you found...
- I need to know if I am still facing a power board issue or deeper such as light engine circuit boards, the light engine...ballast board...etc.
- I ususpect there is some component on the FMT board that went south requiring the unplug and plug in procedure to get past the blinking green light.
Thanks much!
Bladerunner in Navarre Florida
Hogan
I replaced the caps on my WS
I replaced the caps on my WS-65511. Then the IC Convergence and all the pico fuses. Then the E2P. Still the @&%#* green blinking light.
Then, I noticed several miniscule black squares with a smaller square inside them on two boards and the DEMOD-B. They are flush with the surface.
I looked on other boards and found the same "square with a square inside". Except they were copper in color.
My suspicion is that these are an internal fuse of some sort. And the black ones mean the board is fried. Can anyone confirm my suspicion?
-- Hogan
JOrtiz
Please add me to your list of
Please add me to your list of documents and manuals for the mistsubishi WD62725. Same dreaded green blinking light
bsmith11
JOrtiz said: Please add me to
JOrtiz said: Please add me to your list of documents and manuals for the mistsubishi WD62725. Same dreaded green blinking light
If you provide email address I can share with you if you haven't gotten them yet
JOrtiz
Im sorrry here it is
Im sorrry here it is [email protected]
Thank you
Da Chief
I called the Mitsubishi
I called the Mitsubishi service guy here in town...he said my WD-Y65 had a thermal sensor recall. He came and replaced it and works great so far. :) No blinking light!
Fixitall
Can you please send me a copy of the instructions @ [email protected]
sallysmith
I, too, have the blinking
I, too, have the blinking light problem with my WS 65613---TV won't turn on. Would appreciate it if someone would email the directions for replacing the caps:
Thanks in advance.
Megz
It would appear that I have the same constant green blinking light of death that everyone else seems to have...mine is a 6 year old model....Canyou please forward me a solution?
Megan
Scotty1548
I am having this same problem
I am having this same problem w/ the WS-65513. I've opened up the back, and my DM looks a little different from pics of other models that i've seen online. Is it even possible to open the DM box on this one? Could you please send me those instructions too? Thanks.
Scotty1548
I am also having this problem
I am also having this problem w/ me WS 65-513. Could you also email me the instructions? [email protected]
daddymouse
Larry, could you please e
Larry, could you please e-mail me the instructions to replace the 4 capitors on the DM board for the Mitsubishi TV WS-65513? I greatly appreciate your help.
daddymouse
Instructions plase?
Instructions plase? [email protected]
Jasondgrau
Can you please send me those instructions for a wd-5275. My set is doing the same blinking green light problem. Thanks a lot I really appreciate it!
ROSA MARTINEZ
HELLO SIR,MY HUSBAND IS VERY
HELLO SIR,MY HUSBAND IS VERY HANDY AND WE WILL APPRECIATE IT VERY MUCH IF YOU CAN E MAIL ME A PRINT OR PITURE ON WHERE TO FIND THE CAPACITORS ON DM BOARD OR ANY TYPE OF INFO. THANK YOU FOR YOUR HELP HOPE TO HEAR FROM YOU SOON.
ROSA MARTINEZ
Jasondgrau said: Larry, Can
Jasondgrau said: Larry, Can you please send me those instructions for a wd-5275. My set is doing the same blinking green light problem. Thanks a lot I really appreciate it! [email protected]
Cherylvb
I am the owner of a green
I am the owner of a green light blinking wd-52525. I would appreicate the repair instructions as well. Thank you [email protected]
jiminsj
Hi, I am now also a member of
Hi, I am now also a member of the flashing green light club. Are those instructions still available?
J
Wiswally
I have a Mitsubishi WS-65857
I have a Mitsubishi WS-65857 that will only power up briefly after being unplugged for several hours. Could this unit have the cap problem and if so could you send me the info on the repair? [email protected]
Thanks,Dave
RalphN
Larry, please send me the
Larry, please send me the manual. My WD-52725 went out this morning - rapidly blinking green light. Thanks
Ralph
john316
I have the WS-65513 and the power light would come on for a few seconds then go out. Can you send me the factory service repair manual. Thank you.
email [email protected]
addisonbr
Hello Larry, we are having
Hello Larry, we are having the same problem with our WD-62725. I would be much obliged if you could send the instructions to addisonbr / AT / g m a i l / DOT / c o m
Thanks very much.
texas help needed
Hey Larry,
Hey Larry,
I could really use the directions on how to cure the bliking green light on my Mitsu TV. I hear your the man. Please e-mail me at [email protected]
Thank you
slimecuda
Hey Larry,
Hey Larry,
I have the same problem with my Mitsubishi WD-52627 V29 chassis. I stated another post asking for the service manual then saw this post. If you happen to have the procedure or manual for my unit please send to [email protected]
Thanks very much.
Hogan
Does anyone have any
Does anyone have any suggestions on how to move the blue vertical convergence on a WS-65511? I can align the red vertical and red horizontal. And I can align the blue horizontal ... but not the blue vertical.
I have replaced the convergence IC (STK-393-110) ... twice. Both times it was a Sanyo part. And I've replaced the 7 capacitors on the DM Power board.
Any ideas what to check next?
-- Hogan ([email protected])
MikeJames
Hi, I was reading the post
Hi, I was reading the post about the Mitsubishi tv Blinking light problem and mine is out also, I sure could use those instructions for the repair, [email protected] I have changed the lamp that lasted about three months and then the ballast went out I thought but did not fix completely, I have a screen but it is a checker board, I would like to change capasitors before giving up, Have a good day Mike.
Topic locked
