i may have responded incorrectly?? Would you have any information on setting the convergence. I have a consumer electronics technician background (although it has been a while) and have experience doing convergence on projection sets. I also have a test pattern generator with crosshatch pattern. Does this set have a board with convergence controls or is it done electronically? If electronically, how do i access the programming?
I have a WS-65513 and have the blinking green light also. We just had several power outages and now I have this problem. Can you send me a copy of the repair procedure?
I have a Mitsubishi WS-65513. We just had several power outages, and now that the power is back on, I have the dreaded blinking green light. Tried unplugging it and resetting it with no luck. Can you please email me the directions.
Louis Smith
We have a 6 year old Mitsubishi WS55511 that has the famous green blinking light after a power outage. Tried the unplugging and resetting and were unsuccessful. Now we'd like to try the repair you have the instructions for. Could you please send it to: [email protected] Thank you so much.
Larry i talked to mitsubishi tech and they were no help i then say the e-mail regarding the cold wether and i started to wonder what would hapen if i heated up the the tv. I heated up the box in the back of the tv where the capacitors are and after the box was hot the tv came on and it has been working ever sence.
ptyphoon said: Hi Larry, We have a 6 year old Mitsubishi WS55511 that has the famous green blinking light after a power outage. Tried the unplugging and resetting and were unsuccessful. Now we'd like to try the repair you have the instructions for. Could you please send it to: [email protected] Thank you so much
try heating up the box in the back of the tv . I just did this and my tv came on.
Larry, I have the same blinking problem on my Mitsubishi WS-65813 that started after a power outage. I would appriciate an email with instructions to fix this problem. My email address is [email protected] Thanks very much. Regards, Vince
Somehow I can"t find the repair instructions you sent me for the blinking green light problem on my WS-65909...Could you please re-send them to me???? Thank you again!
Larry - please send me the instructions also. Blinking light issue, less than one month after 48 month extended warrentee expired! Thx in advance....Enty
We had power outages a little while ago and since then, my Mits 55" tv has not been the same. Since I have a surge protector, I originally thought that the digital cable box was to blame for the eternal blinking green timer light. On occasion, the digital box would reboot and then my tv would start the timer all over again. Now, I have a new digital box and the tv is still blinking.
Can you send the instructions for the capicitor replacement to my email. I guess that is my next step.
I too have the infamous green blinking light on my Mitsubishi WS-65513. Please forward the docs to [email protected]. I'm an experienced solderer and my wife is a professional solderer, so between the two of us we should be able to accomplish this task. Your help is greatly appreciated.
Sounds like a broken record here...but I have the same problem too. I am very experience with the solder iron and would really appreciate it if you could send me the information you have for this fix.
I have the same problem with the blinking green light on my Mitsubishi 55511. I lost my manual and do not know where to locate the four capacitors that would need replacing. Can you send me info?
there are seven caps you need to replace Jack but how can I send it to you?? I cannot read between the lines and guess whaere or what your e-mail is???
I have removed the dm board with the 7 caps on but the problem now is where can I find the caps? I called my local tv repair that specializes in big screen repair but they wont repair just the board they want the tv and $800. I tried radio schac, frys electronics etc..any suggestions
Louis Smith
Sorry, I guess this would help. [email protected]
Louis Smith
Larry I have a Mitsu WS-55859 that has the dreaded blinking green light as well. I would appreciate the directions.
Tom
Same problem - is it still possible to get the instructions emailed to me? tkx in advance...!!!
Hi Larry, do you have instructions to replace those bad convergence IC's
Larry
Another casulty. Can you email your repair for the capacitors @ [email protected]
thanks
jack
I have the same problem wit the blinking green light. Can you email the fix-it repair manual?
thanbks
jack
I did the capacitor change out, but still have the blinking light. It was worth a try though.
Gary
Help! I have the same problem. I have a WS65613. Could you send me the instuctions also, to: [email protected]
Larry -
Hello!
Thank you.
Same problem. Can you email the information too @ [email protected]
HI Larry, could you send instructions to replace those bad convergence IC's on my WS 55513
I have the oppurtunity to get a 65
thanks
jack
Larry
Jack here. I need the information on the 7 caps that need to be replaced. Sorry about that here is my email [email protected]
thanks jack
I have the same issue with the green blinking light on our WS65513. Can you please forward me the instructions so I can repair! Thank you!
I'm confused I thought there were only 4 that needed to be replaced. I got mine at mouser.com
if you could please email the instructions for this type of repair, thanks.
