2603 posts / 0 new
Banshee
Still waiting for a decision
Still waiting for a decision from Mitsubishi.  I feel they are going to reimburse me the entire amount of the repair.  We'll see.
repman
Larry Dillon said: They will
Larry Dillon said: They will be sent out in just a short time to you. Good Luck!
hello larry
  could you please send me the directions  for the mitsubishi ws-65513 blinking green light problem.
  at [email protected]
                                                      Thanks Tom
SMSgt
Banshee,
Banshee,
 Please keep us all posted on the response you get.   I have sent three very polite e-mails to Mistsubishi ([email protected]) concerning my problem, to no avail.  I also believe Mitsu needs to face this "obvious" problem with their products.
ALSO - Thanks Larry! for helping so many people.
Jon
I noticed that the timer
I noticed that the timer light on my four year old Mitsu 65 incher was blinking and the TV wouldn't power on. The reset switch didn't fix the problem does anyone have an ideau what could casue this, I have been reading on sites about 4 capacitors and if there is an easier fix than spending about $700 to correct problem i am all ears.
Please Help
Let us know what was decided
Let us know what was decided Banshee.  I have included all who are requesting the DM fix and repair who left a GOOD e-mail address. Gerard, I have a fix for you if you can solder and follow simple instructions. You could put that 700 to 1000 bucks into your own pocket. Good Luck with your repairs.
Mr. Jim
Larry Dillon said: When you
Larry Dillon said: When you get your manual, you will see the diagnostics test shows that a 2-2 blink means short protect. That means the power supply detected an large amount of current draw and shut down because of a short in the set. Most likely in this set, you have a bad convergence IC. You will however still need to change those seven capacitors in the DM board and if you do not, they could blow out the DM module, and at a cost of about 1000 bucks, I think 10 bucks worth of capacitors is worth saving 1000 bucks. In this model there is only one convergence IC. It's number is the STK393-110. Good Luck with your repair.
Hey Larry,
I wrote to you on December 27th with a WS-55859 than shuts down after 5-seconds.  It has a diagnostic code of 2-2.  I followed your suggestions and replaced the STK393-110 convergence IC and, for my own piece of mind, the entire DM board.  The TV still shuts down after 5-seconds.  Am I missing something or do you have any other suggestions?
 Thanks.
seniomsed
Larry, I fixed my blinking
Larry, I fixed my blinking light(DM board)problem per your directions. Our Mitsubishi 65513 is now working  perfectly!  While the tv was cracked open I cleaned the lamps and installed the 12v PC fan as you suggested.  Thanks for the very detailed directions and manual.  The 4 bad and bulging capacitors were indeed the culprit. I replaced them with 1000uf 16v. 105 degree c radial caps. I used the de-soldering tool you recommended from Radio Shack(the one with the red squeeze bulb)It worked easily as I practiced on an old pcb before attempting the real repair. I learned just as a previous member stated it is very important to install the DM board 1st and then the sheilding box(with already attached fan)to ensure the board has made a solid connection. Also I must add their is black plastic dust and light shield directly above the DM module that must be removed before installing the DM sheilding box. There are also 6 connectors that need detached before sliding out the tray and one long black screw. I was careful to note their location as to not miss one when putting everything back together.
With much gratitude and praise, thank you for your expertise and kindness.
-senioM seD
Great news! You were able to
Great news! You were able to follow directions and repair your TV set. Feels good to put that 1000 bucks into your pocket!
mrjimmy, you might have a
mrjimmy, you might have a short in the main power supply board. You will need to look at the schematic and make sure you have all of the standby voltages as well as the switched voltages. ptscorp.com does do board level repairs on these power supplies, at least they used to. I have heard that if you take out the entire chassis, they will repair it and overhaul anything needed to be done for about 300 bucks or so.
Ron Repking (not verified)
Larry Dillon said: yes let me
Larry Dillon said: yes let me see the pictures at [email protected]
Larry I'm in the same boat as so many others that you have helped with their Mitsubishi projection TV.   I have a Mitsubishi WS-65513, and it currently has no picture and the green power light flashes on and off.
It would be greatly appreciated if you could send me the repair and service manual for my TV.  I believe I can fix it myself with your help.
Thanks Lem R.
Sorry Larry, I forgot to
Sorry Larry, I forgot to include my e-mail address for the service and repair manual! My address is
testuser2
Like everyone else in this
Like everyone else in this thread, I've encountered the blinking green light on my Mits WS65513... tried all the standard fixes, and am convinced after reading this board that I have the same capacitor problems as everyone else.  Could you send me a copy of the fix.  I would really appreciate any help and will let you know how it goes.
My email address is [email protected].
Thank you so much for any help you can give me. I was getting no where until I found this board.
Animal
reneej
Larry:
Larry:
I just  discovered today that I have the same green light blinking problem on my Ws-65513.  I am encouraged by the prior posts that this might be the capcitor issue Cry.  Would you mind sending the repair and service manual to me and the instructions on changing out the caps.  I would like to give the repair a shot myself before calling the TV store to come and get it.. Many thanks. Please email me at [email protected].
GOCCINC
I just found this site.  I
I just found this site.  I came home from a week away and found the green light blinking on my Mit WS-55513.  I see you have a possible fix for it.  Would you please send it to me.  I would like to fix it myself.  Thank you. [email protected]
I have sent to all those who
I have sent to all those who have sent an e-mail address, the fix to repair their own TV set. To you all, Good Luck.
thebitguru
Larry, you forgot about me
Larry, you forgot about me again :(  Can you please email it to me at [email protected]?  Thanks!
arkie
  I am have the green light
  I am have the green light binking problem......may someone send me the instructions for WS55909 model on how to repair?
Thanks!!
Albert1 email: [email protected]
thebitguru, I did send those,
thebitguru, I did send those, what model number are you looking for?
thebitguru
WS-55513.  I am guessing my
WS-55513.  I am guessing my host must have blocked it.  Can you please try again?  Thanks!
I sure will, I am getting
I sure will, I am getting ready to send out several.
thebitguru
I got 'em this time.  I will
I got 'em this time.  I will read through them tonight, thank you very much!
jnesci
Larry could you email me your
Larry could you email me your directions for the "Blinking LED" problem capacitor repair. I have a friend that had there TV do this and I would like to help them fix it. I am a broadcast engineer for one of the major networks so have plenty of soldering experience and most of the problems we have with professional gear is now leaky capacitors. You can email me at [email protected] I do not have a service manual on this but will order one if needed. Thank You in advanceFrank G.
Frank, no need to get a
Frank, no need to get a service manual, I will send you the factory service manual as well as the documents on the capacitor replacement. Good Luck with the repair.
Jon
Lary could you email me the
Lary could you email me the fix for the green blinking light issue on mitsubishi ws65513, I would like to replace the capacitors on the dm board as i have read on the forum @ [email protected]
Gerald, I have sent out those
Gerald, I have sent out those repair documents as well as the service manual. Good Luck
Tie Guy
Larry,   Could you please
Larry,   Could you please send me the repair manuel for the blinking green light problem.  I have a very qualified electronics professional who is going to replace the capacitors on the dm board.  I am hopeful this will fix the problem.   Our TV is over 3-1/2 years old.  It did this just less than two months ago, but after leaving it unplugged overnight, the TV starting working again.   This time, it will not come back on.   Please send to:  [email protected]
Sure mapperman. I will send
Sure mapperman. I will send out the repair documents as well as the service manual for you. Good Luck with the repair.
Crackerbox
38 pages of Mitsubishi
38 pages of Mitsubishi capacitor DM failures in this thread, seems Larry, you have become a slave to this defect.  How do you find the time?  Does this forum have any other thread as robust?  I smell Class Action.
I study online and have what
I study online and have what's called sleep apnea. I do my studies in between the DM saga.
Joe Mama
Can I get a "me too" on the manual and repair doc?
 thanks,
Mike
Topic locked
