Read through the whole thread, but didn't see a symptom like mine. I replaced the 7 caps on my WS 55859 - I have the picture back, but no menu on the DTV input. I can use the Device to change to each of the inputs, but nothing displays. I can see the menu on Ant A, but not on DTV. Any ideas?
any of tese symtoms?
If picture is dark or goes dark intermittently with lines and or fuzzy picture or if the screen turns blue and the set shuts off, check IC9C25. Could be bad, or bad connections It is on the signal board. Right behind the input or whatÂ’s called the terminal board. The IC is a BA09FP. This IC supplies 9 volts to the terminal board. Try resolding it first.
IC9C25 (9-volt regulator) part # 270P677030. BA09FP regulator from B&D Enterprises in Russell, Pa. http://www.bdent.com Thanks to our member NEXNUXS for sharing this info wih us.
Hello Larry, Could you be so kind to send me the infromation for the blinking problem on the wd 52525. I have the blink of death also. My email is [email protected] thanks so much. mz
I've read the threads and am quite excited to see that you may have repair instructions to fix the dreaded green timer light blinking into infinity? We have a WS-55859 which began this problem after the power was restored during an overnight snowstorm. Would you be able to forward those instructions to us at [email protected]? Thank you kindly! :)
On this set, i'm working for 3 months i never get work i did everything changed caps on DM board/the 2 stk's check power supply i have all vots,but i din't get work. need help please thanks.
I have a mitsubishi WS-65613 big screen that was working fine until I turned it off and decided to turn it back on later but only get a constant blinking green power light on the front panel.Please let me know what to troubleshoot and possibly repair.I cant afford a new set and dont want to miss wrestlemania 25 pay per view coming up soon.Thanks.
I also have the same issue with my ws-55511 Mitsubishi tv. The flashing light and no picture or sound. Can i get some help with the issue? [email protected]
I have the wd-52725 with the flashing green timer light any help on how to repair would be extreamly appreciated. You can email me at [email protected]. Thank you so much
Tate said: Larry, Can you please send me the instructions for the green blinking light. I am having the same problem with my Mitsubishi 55" wide screen. Thanks.... [email protected]
Hi, Im having the same prob. with our tv.. id you still have the instructions for the blinking green light could you email them to me at [email protected]
I have the same issue larry with my WS 65909. Green light blinks repeatedly. After changing the 7 caps still same problem. Can you send me the info on how to fix the blinking green light problem. The two fuses on the small dm power board show good. [email protected]
What you will need then is a multimeter to check all the voltages from the switched and unswitched power supply going to the DM, If those are all good then the DM is most likely bad. you can go to PTSCORP.com find their number and see if they can rebuild the DM and how much it is
I have a mitsubishi 55909... I unplugged it b/c storm was coming; missed storm but TV won't come on after plugging on :-(.
Now ONLY HAVE BLINKING GREEN LIGHT!!! NO MONEY TO FIX...PLEASE HELP!!
WOULD GREATLY APPRECIATE any REPAIR INSTRUCTIONS YOU CAN SEND..THANKS KINDLY!!!
hello i have a ws-55859 mitsubishi i plugged it in and pressed down the power button as i held it a green light would start to blink.as long as i held the power button down it started blinking but as soon as i let go it stops can you tell me what i need to do to get this tv working.
Robert
did you check the small fuses on the DM board?
big screen trouble how am I suppose to help you if I dont know where to send the repair info?
Please email me at [email protected] for my ws-65613 troubles
I have a Mitsu WD-62825 Blinking light of death television series could you please send me the instructions for the dm removal.
Thankyou
Tim
thanks again
Could you send me a copy of the instructions. Same problem on the WD 57731.
Thank you for your time. [email protected]
lauren
lauren
Hello, I've changed the copacitors on the dm board green light still flashing what now?
Nick, What model number are you working on? always mention model and e-mail please as I do not remember from all the request I receive.
hey larry can you send me the inforamation to fix my wd-52525 green blinking light
send them to [email protected]
CAN SOMEONE PLEASE SEND ME THE REPAIR INSTRUCTIONS FOR THE BLINKING GREEN LIGHT. MITSUBISHI MODEL WS-55859. THANK YOU VERY MUCH.
SHAWN
CAN SOMEONE PLEASE EMAIL ME THE REPAIR INSTRUCTIONS FOR THE GREEN BLINKING LIGHT. MITSUBISHI WS-55859. THANK YOU. [email protected]
THANKS,
SHAWN
THANKS,
SHAWN
Sharon I need AN E Address to send it to!!!!
Larry -
My email address is [email protected].
Thanks so much!!!
Hi,
I have the blinking green light on my WS-55613. Could you send me any info on how to remove/service the DM module? [email protected]
