1638 posts / 0 new
nathan
nathan's picture
Larry,  I have a WS-48515.
Larry,  I have a WS-48515.  Much to my surprise, when I opened it up it is totally different from the WS-48513 that you sent.  The layout is entirerly different.  Do you have anything for the 48515?  Thanks.
Larry Dillon's picture
Tim, I do not have that
Tim, I do not have that manual. But you should be able to look at all of ther info and see where the DM board is located?
par3, There will be a bulk
par3, There will be a bulk mailing tonight with the info you need. Good Luck
callmecajun
callmecajun's picture
Larry
Larry
Do you have the information that will help with the blinking light problem for a ws-73713?
Thanks again for the help
Lewis
lfigh@buckmasters.com
jswieton
jswieton's picture
Larry or anyone who has the
Larry or anyone who has the info,
I am having the same blinking light problem and my local service company wants $625 to replace my DM board.  Can anyone please email my the instructions.  I would greatly appreciate it.  Thanks
jswieton@comcast.net
You only have to post it in
You only have to post it in one place man. I already sent these to you via your e-mail.  Good Luck
kinfolk
kinfolk's picture
Hi Larry, is it just me or is
Hi Larry, is it just me or is there a pattern or life expentancy with DM boards dying. i bought my ws-55513 in early 2004 and when i came home this weekend green flashing light.  would it be possible to get a copy of the reapair instructions? many thanks,
Kin
vincent.adame@usmc.mil
Danno
Danno's picture
Larry Dillon said: That's
Larry Dillon said: That's great man! I am going to be passing this on to all those who this repair did not help. Good Job! Thanks for letting us know.
 Could you send me the instructions as well?  I have a WS-65813 with the same blinking green light issue that everybody else has.  It's maddening that Mits has this problem and doesn't acknowledge it.  I've had my good old Toshiba 55" for 12 years without a hitch.  My Mits is only 3 years old and already the blinking green light.
Danno
Danno
Danno's picture
Could you send them to me as well.  I have a WS-65813 with the same blinking green light.  It's maddening!  My good old Toshiba is 10 years old and still going.
Danno
BobDMK
BobDMK's picture
I unplugged my Mitsubishi
I unplugged my Mitsubishi WS55859 to get rid of a black dot. (I had four white dots a few weeks ago and uplugging it resolved that problem so I thought it would work again.) Now I am not able to power it back on. The green timer light is blinking and I tried resetting but that doesn't work. This problem must be the same as everyone is posting here. Please send the fix to me also. Thanks for your help.
dbkeefer@netecin.net
kinfolk
kinfolk's picture
Hey guys i found this thread
Hey guys i found this thread on another forum hope it helps.
http://www.hdtvoice.com/voice/showthread.php?t=32186
BobDMK
BobDMK's picture
I can't find 25v 105c
I can't find 25v 105c capacitors but have some 35v 85c that I can use until I can get the others. They are bigger but fit ok. How long will the 85c last? Should I replace them next week when the others come or can I leave as is until they quit? Right now the TV works again. Hate to change it unless I have to. Thanks.
ArthurG
ArthurG's picture
Just got home and mu 55613
Just got home and mu 55613 has the dreaded blinking light that won't turn off.  Please send me the repair instructions.  ageffen@airmail.net
Thanks.
If the set went out and then
If the set went out and then started to work again, change the capacitors before they cause more damage to the DM board. I have seen this happen on most of the sets where the capacitors are changed and the set will not work. You ask the customer about the symptom, the customer says yea the TV set use to go out every once in a while but started to work again.
I am sending out a large bulk
I am sending out a large bulk mailing to lots of peeps tonight. You should have the documents and directions tonight. Good Luck.
winnie247
winnie247's picture
Larry, could you please send
Larry, could you please send me the repair instructions.  wgordon3144@ca.rr.com
BobDMK
BobDMK's picture
Larry Dillon said: If you
Larry Dillon said: If you have to order them, make sure you get the 105C type. These are the hi-temp. caps. NOT the 85C type.
I ordered the 105c.  I have the 85c already soldered in. Should I replace them immediately or can I leave them in until they go out.
HiTekBill
HiTekBill's picture
Larry,I would appreciate it
Larry,I would appreciate it if you could you send me the repair instructions,manual,schematics,pics,etc. for my WD-62825 DLP TV. The dreaded fast blinking timer light.
W_Haan@msn.com
Slide
Slide's picture
Larry, I wish I had seen this
Larry, I wish I had seen this thread long ago.  My 65813 has had the banding lines and it has gone out on me before, but now it is getting persistent.  My hope for winter break is to do this fix.  If you could email me the information as well I'd really appreciate it.
 Thank you,
 ndutta14@yahoo.com
I will be sending out the
I will be sending out the manuals and documentation in just a little while for all those who posted for the info on the 513, 613, 713 type sets. All others please ask on the correct model number thread or start one with the proper model number. With the overwhelming requests, I cannot start and stop sending to all at once. Thanks. Good Luck to all.
BobDMK, you can certainly use
BobDMK, you can certainly use those, but for reliability, I personaly would use the 105c. Good Luck
leidout
leidout's picture
Larry, could you please send me the documents as well, my WS-65613 just got this problem... had no idea it was this common...
My email is leidout1@yahoo.com
Thanks very much for all your help.
leidout, the info will be
leidout, the info will be going out this morning. Good Luck
avsourmash
avsourmash's picture
Larry, could you please send me the manuals & documents also; my WS-65813 just got this problem several days ago.
My email: rbjones@gmail.com
Thank you so much!!
avsourmash, you should
avsourmash, you should receive it sometime tonight. Good Luck
Travcoop
Travcoop's picture
 I'm gonna hop on the band wagon...have a WS-65813 green light just keeps on blinking...please email me all the stuff I need if you don't mind.
travcoop1@gmail.com
ps-happy thanksgiving...thanks in advance
chaluk
chaluk's picture
I also have the blinking
I also have the blinking green light on my WS-55613. Can you email me the info on how to change the caps out? chaluk65@gmail.com Thanks, chaluk
Travcoop
Travcoop's picture
Still haven't recieved the
Still haven't recieved the email...would you mind sending it again...
travcoop1@gmail.com
thanks in advance
I sent all these out this
I sent all these out this afternoon. Wow, now I think most of these are not going through. I have sent it again. Please confirm when you receive this please via e-mail. God Luck
zauberer
zauberer's picture
Seems I am not alone here, I
Seems I am not alone here, I also have the blinking light problem on my WS-55513 please send me the instructions and parts list for the repair.
Thank You !!
thepcwizard1@mchsi.com.
