1639 posts / 0 new
Speed
Speed's picture
Larry & Riley, I received the WS-65813 service manual that you sent and replaced the 4 CAPS on the DM Module with 1000uF, 35V, 105c capacitors. Verified cap polarity and proper solder connections. Upon power up, have the same issue: continuous "Blinking Green Light". Reset button has no effect. The unit makes NO unusual sounds. Could the eeprom board be bad. Is it labeled "E2P" on the DM circuit board. Any suggestions regarding where I might obtain a replacement eeprom or other circuit board parts. Do you have any additional troubleshooting advice. Your suggestions are appreciated.
By way of information, I sent a letter to Mitsubishi's Consumer Relations Department with a copy to Mitsubishi's President and CEO discussing this issue.  vicnlinda@hotmail.com
Speed
The following link has been added to this thread: http://www.techlore.com/article/24711/Mitsubishi-Blinking-Green-Light-Re...
Follow the repair procedure discussed in this Article to replace bad capacitors. A service manual link is provided for those in need of a Mitsubishi Service Manual for your specific Model.
Good luck in the repair.
Larry Dillon's picture
Speed, You will need to
Speed, You will need to contact an authorized Mitsubishi parts house and ask them, as the manual does not even have a schematic or parts list for the DM board, only a part number for the entire board. I have never replaced the eeprom board in one of these TV sets. If the Caps do not fix the problem, I'm afraid the only option is to replace the DM. Good Luck
Lou
Lou's picture
Larry, I now have the
Larry, I now have the Mitsubishi WS-65813 television up and running. The "blinking green light" issue has been resolved.
Lesson Learned: For your information and others, after replacing the 4 capacitors on the DM Module, I slid the DM circuit board back into the metal DM case and then inserted the entire unit into the main circuit board. This was working in the "blind" as it was impossible to verify a proper seat of the DM circuit board onto the mother board.  The blinking green light was still present upon power-up of the TV. I again removed the DM module from the TV and this time I re-installed the DM circuit board onto the main mother board and THEN installed the DM metal case over the top of the circuit board. By doing this, I was able to ensure a proper connection of the DM board. Upon power-up the TV is UP and RUNNING.
Thank you for your assistance.
Speed
That's great man! I am going
That's great man! I am going to be passing this on to all those who this repair did not help. Good Job! Thanks for letting us know.
Bob
Bob's picture
Larry,  it would be
Larry,  it would be appreciated if you can send the instructions you have to fix the DM module for the WS-65813.  I have the blinking light.  thanks.  keith.olander@yahoo.com
Thom Wood
Thom Wood's picture
My six year old t.v.
My six year old t.v. Mitsubishi WS65513 doesn't power on anymore. I am having the same blinking timer light problem. I tried clicking the reset button but no luck. I went and talked to a t.v. repair man and he said it could be the power supply where he would need to replace three circuit boards and it would cost between $400-$800. I had a different problem with it three years ago where the t.v. would just turn off for no reason and that cost me $500. I was just about to get rid of it until I saw this sight. I have a couple of question. What is the location of the circuit board with the blown capacitors? You mentioned the type of capacitors to replace them with could you let me know what they are? Also, how delicate is the circuit board to heat? I have had some experience soldering small circuit board connection. What should I be careful with when replacing these circuit borads? I would appreciate it if you could send me the instructions along with my circuit board questions. My e-mail address is stephenj@surewest.net
Thank you so much. You are a life saver. Hopefully I won't have to buy a new t.v.
blondie42550
blondie42550's picture
Larry and new friends -
I have a WS-55613 with this same blinking green LED light continuously flashing away.  It started the morning of Tuesday.  The television was working TIP TOP and I had just had ATT's U-verse put in over the weekend and was still blown away of the clarity of the HD channels.  I felt my 3 year old tv was still better than all that plasma stuff.
 The next morning my fiance went to turn it on and it just went into flashing LED mode and does not do anything else.  I have pretty much spent a few hours reading and I am certain it's these capacitors on the DM module and I am just aching to spend the weekend repairing it.
Larry, would you please send me the great work you've completed on successfully repairing this DM module that everybody is talking about?  please send it to RCi30@aol.com
I can't tell you enough how helpful it would be.  BY chance do you have any Fry's Electronics or Radioshack part numbers to these capacitors that have proven to be effective in repairing this module handy?  I could just start calling these stores and making sure they have them.  I believe this model tv has 7 total that I should change, correct?
Thank you SO much in advance.  I'm excited about getting my Mitsu and repairing its issues.
Ryan
Ryan, I have sent you the
Ryan, I have sent you the info for your TV set. If I am not mistaking, your model of TV set has only 4 capacitors in the DM board. Read everything I sent top you and compare. Good Luck
char
char's picture
Larry Dillon said: Ryan, I
Larry Dillon said: Ryan, I have sent you the info for your TV set. If I am not mistaking, your model of TV set has only 4 capacitors in the DM board. Read everything I sent top you and compare. Good Luck
I am having the exact same problem with my television.  Can you please sent me the instructions to haimir2@sbcglobal.net.  I also have a WS55612
Thank you.
Are you sure of this model
Are you sure of this model number karensf? Does not look right?
blondie42550
To Jon -
To Jon -
 Everybody, I did the cap swap on my WS-55613 and it couldn't have been any easier.  A simple swap and it cleared my problem up and I was enjoying CRYSTAL clear HD football all Sunday with my fiance and some Oktoberfests.
 It was SO simple and I can NOT believe that TV repair people charge up to $700+ dollars for this repair.  The hardest part about it is the simple fear that you think it is harder than you think.
 Go buy 16V OR 25V 1000uf 105C caps at any store that sells capacitors.  DO NOT get the 85C, they MUST MUST MUST be high temp.  the 25V just work harder and better.  Like installing a supercharger in your engine.
 Simple swap, you should practice first by taking off a cap off an old remote control or old electronic that is lying around, you will get the soldering iron down quick.  If not, GO TO A NEARBY FLEA MARKET, there are trades men EVERY where that will do it for next to nothing.  I did mine myself with the help of my brother.
I installed them, swapped the tv on, and within 1 minute the blinking green light stopped blinking...and viola...crystal HD viewing.  Jon, you saved my bank account.
People, total cost:  $8.74 for all 4 caps and roughly 4 - 5 hours of time, with driving, breaks in between and actual soldering time.
GOOD LUCK and yes, get Larry's diagram, it does help.
Victor Coronato
Victor Coronato's picture
We have the blinking light on a WS-55513.  We replaced the 4 captors on the DM module and still no luck.  Would you please send us the information that has helped so many others?
Thank you in advance.
cantaim@sbcglobal.net
cantaim, I have sent you the
cantaim, I have sent you the documents. Make sure the board is seated well into the board below the DM board. Also read the article, it explains about some small surface mounted fuses that go bad sometimes also. Good Luck
franky
franky's picture
HELP!!
HELP!!
Can some one please send me either a diagram or pics of the location of the capacitors that I need to replace??
Greatly apreciative.
Where do you want them sent
Where do you want them sent to and what model number of TV set? I ccannot send something without an e-mail address.
franky
franky's picture
DUH, sorry about that I'm new
DUH, sorry about that I'm new to this kind of stuff. My model# WS-55613 and my e-mail is jadincorp@msn.com
Thanks in advance.
franky
franky's picture
As I'm considering fixing my
As I'm considering fixing my current set, what do smoe of you think about the latest Big screen craze? And which is better LCD or PLasma?
unc132
unc132's picture
Hi I have the same prolem
Hi I have the same prolem with the green blinking light. Can someone help me this problem. I see someone has repair instructions and manual mine is a mitsubishi ws-55615. I would be greatfully thankful
Bill, to where? I am not a
Bill, to where? I am not a fortune teller man.
dvdmrp
dvdmrp's picture
Larry, Same problem with the
Larry, Same problem with the blinking lights of my ws-65813. Can you please forward to me the repair with pictures. Thanks Jeff jefj15@hotmail.com
unc132
unc132's picture
Hello I dont know if i am
Hello I dont know if i am sending the question to the correct person but I need diagrams and repair manual for ms-55615 big screen because of a constant blinking light. Please email at w.wilson@charter.net
Juliepearlie
Juliepearlie's picture
Larry, I also have the same
Larry, I also have the same problem on ws65813.Could I also get info on how to repair the blinking light fix.
Thanks Rob
robriding@cox.net
nathan
nathan's picture
Larry,  I have a WS-48515 and
Larry,  I have a WS-48515 and the same blinking light problem.  Could I get a copy of the repair instructions as well?  Many thanks,
Tim
dreyer1@comcast.net
I am sending you the
I am sending you the documents you requested, Good Luck
nathan
nathan's picture
Larry Dillon said: I am
Larry Dillon said: I am sending you the documents you requested, Good Luck
Thanks Larry.  I'll let you know how it turns out.
TimD
DevAdmin
DevAdmin's picture
We are having the same
We are having the same problem, blinking green light, with our Mitsubishi WS65513. Please send information for how I can fix the problem to lucky.tiderman@yahoo.com.
Thank you,
Lucky
Barbara Lynn
Barbara Lynn's picture
I have the ws-55513 and damn
I have the ws-55513 and damn thing just did the blinking light thing.  It is 4 months out of warranty, go figure.  Do you have the scematics to fix the DM module please.  Thanks so much.  i dont have the money to buy another TV or to pay someone to fix it.  Thanks
jake_pruet@hotmail.com
The TechLore Team
The TechLore Team's picture
Help - I have a Mitsubishi WS
Help - I have a Mitsubishi WS 65613 and I am having the same problem:  TV will not power on and has the blinking green light.  I have the service manual but, I need a schmatic or the instruction how to fix the problem.  Can you send to me the instructions that you have sent to everyone.  Thanks so much.
pksides@sbcglobal.net
Barbara Lynn
Did Mitsu fix this problem on
Did Mitsu fix this problem on their new TV's??? I am looking for a new TV for my B-room and dont want the same problem...BTW I have the DM module out and apart, waiting for radio shack to open....
Good Luck sonic, I hope the
Good Luck sonic, I hope the directions are straightforward enough. if you have any questions please ask away. To everyone else who left an e-mail address, the documents should be on their way soon. Good Luck
Barbara Lynn
Well the blinking light is
Well the blinking light is fixed, but when I power up my TV, the green light turns on for about 3 seconds, then it turns off.
