I know this is a well documented issue but if someone has the "fix" for this can you please email it to [email protected]. Thank you.
I wan't to see if I can get any further enjoyment out of the last Mitsubishi DLP I will ever buy. Thank you.
Rich
Rich
Copyright © 2020
I have the WD-65732, and I've already had to replace teh heat sensor. Now though when I try to turn the TV on the green light just blinks and it sounds like the TV is tryin to turn on but no light or picture ever comes up and then the TV just powers off. I was gonna order a new bulb but wanted to make sure that it's actually my bulb that's bad.
Does anyone have a fix for this issue. If so please email to me at [email protected]
thanks in advance
did you ever fix this? i'm having the same problem now and I don't know if it's the ballast or the bulb, or both...
