WS-65613 error code 22
omzig123
A friend of mine has a Mitsu 65613 that is flashing code 22 short protect.
Is there a troubleshooting guide on this? He has the repair manual and it mentions code 22 but never states what the causes may be.
 I have not looked at the set yet but was hoping there is a detailed guide for the errors and test points to check. I have read the common problem to be the STK392-250's to be a problem but would like the prove that before just replacing.
 He also had a repair shop replace the 4 caps that typically go bad about 6 months ago or so.
 Thanks, i can be emailed at omzig at yahoo dot com
Mike
omzig123
More info as i have looked at
More info as i have looked at the power board and the F9A05F fuse is blown . All other fuses are ok. Diodes 60 and 61 are ok
