I have a Sony projection TV KP-46WT510, when the set is turned on the
standby light blinks four times. I have replaced IC8003(LA78045). (the
board number is A1302708A)
After replacing the IC I am still experiencing the same problem as the
standby light is still blinking four times. I am asking if anyone can
assist me with the problem and a service manual will be greatly
appreciated. thanks in advance.
sony kp-46wt510 blinks 4 times
Thu, 09/27/2007 - 12:12
standby light is still blinking four times. I am asking if you can
If that is the vertical IC, you will need to also check the b+ feed coming from the sweep power supply. Hopefully the supply did not burn out the new IC. Also in these TV sets you have resistors as well as capacitors that can go bad at the same time. I do have a service manual but you left no place to send it? You could go and buy one at servicemanuals.net if you do not want to leave an e-mail address. Good Luck
the b+ voltage is 24volts.i replace c8005,c8006,c8153,c8015.when i checked pin 1 there was no pulse on la7845.vertical drive is on R8237 but zero on the othe side.my email address is [email protected] thanks in advance
check pin 3 and 5 of cn8006 for vertical dirve(oscilloscope i am assuming you have one), pin 3 is + drive 5 is - drive. if they are missing then possiably cn4 is not plugged in tight, this is a common problem with this set.
also you have two power supply voltages for the vertical drive ic on this set
check pin 4 and 7 for + 15 and - 15 volts to the vertical drive ic
you have to check these voltages and the pulse before the set goes into shutdown.
24 volts is not correct for this tv.
i dont have my oscilloscope with me.how much voltage should i expect from the b+ ?
+15 and -15 volts are there.the pulse stop at r8237 i dont know the value of that resistor
two b+ voltages pin 4 is one and pin 7 is the other one is +15 volts the other is -15v
r8237 is a 1 meg ohm and not the main signal path the main signal comes from r8147 and then through r8041 then to r8032 then to pin 7 there is both a pos and negitive drive on pins 7 and 1 respectivly.
sorry for that misleading information.do you have a service manual for this set?my email is [email protected] what value is R8147, R8041 and R8032. how much voltage should i expect on the b+ and output?
i think you are headed in the wrong direction those resisters almost never go bad. Sorry, our contract with sony won't allow me to distribute the manuals. but i am trying to help, the horizontal output's power comes in on pin 7 and pin 1 one will be +15 to ground the other will be -15 to ground. you need both voltages for the ic to run.
thanks for helping me so far.where do i go from here?any ideas?
my email:[email protected]
do you have those voltages on pin 7 and pin 1 of the horizontal output ic? - if not then we need to find out why the supply is missing. if you do then we need to look at the horiz drive pulse.
these are the voltage from IC8003-pin1:0,pin2:17.4,pin3:-18.1,pin4:-18.8,pin5:0,pin6:16.7,pin7:0
ok pin 1 = 0 and 7 = 0 means you have no power to the ic. let me look at the skit and get back with you
ok.im presently looking at the pdf file for la78045
on cn5004 on the g board pin 1 should have -15v and pin 3 = +15 check to see if you get these voltages at that connector
pin1 -18.8volts and pin3 +17.5 volts
ok good, that means the ps is producing voltage, there is no component between cn5004 and pin 1 & 7 of the horiz output ic. so there might be a bad trace (open circuit) from that connector to the horz output ic check the board where you solered in the ic and see if you have a broken trace
is it the horzontal output or the vertical ic?
sorry "vertical" output my bad
ok. pin1 from cn5004 goes to pin4 and pin 3 goes to pin 2 of the vertical ic. pin 2 is + volts and pin4 is - volts of the vetical ic
ok after examining the skit that look good, and your voltages are ok, i tried to do this with out the skimatic and there is a version of this ic that used pins 1 and 7 for the voltages that is where i got that from, sorry. it is pin 2,4,6 (6 being the "pump up") and the voltages look ok to me. from your previous post. it is a dirive pusle problem. either missing or not correct.
here is the pin out of ic 8003
1= negitive drive pulse
2 = +15 volt supply
3 = not connected pin(shows wire connected but block diagram of ic shows not used)
4 = -15 volt supply
5 = vertical output
6 = pump up or +15 volts
7 = Positive drive pulse.
there is a service bulliton about cn4 on A board being loose causing no 9 volts to ic 309, which will
prevent the drive pusle from being generated, check pins 55 and 61 of ic309 on the a board for 9 volts. the cn4 provides 11 volts for the 9 v regulator on A board.
sorry for the delayed response, i was out of the country for a few days. i found a cap that had short- (16v -100uf) c443 that goes across pin 61 and 55 on IC309 on the A-board. afer replacing the cap i was only getting 2.7 volts. however that was incorrect. i tried to trace it back to the regulator but was unsuccessful. i believe that there is a resistor in line that had lost its value. the service manual that i have did not have the scematic diagram for IC309 on the A-board. i sent 9 volts to pin 55 & 61 and the set came up nicely. i still need to find the 9 volts source . a lot of thanks and respect for your help. if you have any problem and need assistance, please do not hesitate to e-mail me.
Glad to see that you found it, it probably is the regulator. Finding the shorted cap could have loaded down the regulator causing it to malfunction.
That 9 volt regualtor does go bad in these sets. I have replaced several of them over the years.
the regulator is not bad,tracing the line from pin 61 and 55 back to the regulator is giving me hell.
the regulator is ok,the line from pin 61 ond 55 back to the regulator is giving me hell.i think that a resistor on that line as lost its value
ok,the regulator seems to be ok.tracing the line from pin 61and 55 is giving me hell.
If the schematic does not show any parts along the way, simply connect a wire from the regulator output to the IC.
