I purchased this tv in 1999 and came home to the dreaded blinking green light. Saw a bit of smoke come from the area that looked like the power supply. I have gotten an estimate to fix the power supply using a rebuild, which, after reading some of the forums, he might only be replacing the capacitors. He says a new power supply is about $500 before install. My question is what should this rebuild cost and due to the tv age what is the max should I put back into it?
Larry you out there?
