Quick update I have installed all 7 capacitors correctly as per your directions I do not have the green light anymore (Thank Heaven) But the set is not coming on... Is it posible to replace the fuses and are they available anywhere Any help would be appreciated EW
Double check all of your plugs and connectors. Next step would be to go into the service manual you got, and start by checking all of the small on-board fuses in the power supply. You know now that the problem is no longer with your DM if the green light goes off after you plug it in fresh to the outlet. Let me know what fuses are bad first before you replace them.
Hi Larry, I wasnt sure if you got my model number for my Mitsubishi with the flashing green light. Its WS-65869. My email is [email protected]. Thank you in advance for any docs you can send to help me out. Ricky
Larry, thanks for the email. Now i have to find someone to help me open it. LOL. Maybe my computer is too old for zip files. Thanks again. You are saving a lot of people a lot of money. Rick
I have a Mitsubishi WS-55859 with the blinking green light problem. I have pressed the reset button and the light continues to blink. I have unplugged the TV for 12 hours plugged it back in and the light still blinks.
I have had my TV for 6 years. Could I get a copy of the repair instruction and/or the service manual. My email is [email protected].
I am sorry breakaway. It was late, I should have known that. That is the voltage supply fuse for the DM. Replace the capacitors and the fuse. That fuse does blow sometimes when the capacitors blow out. Hopefully nothing else went out . The only way to see is to replace the parts and try it.
Larry Dillon said: I am sorry breakaway. It was late, I should have known that. That is the voltage supply fuse for the DM. Replace the capacitors and the fuse. That fuse does blow sometimes when the capacitors blow out. Hopefully nothing else went out . The only way to see is to replace the parts and try it.
Where do I get a fuse for that otherwise part # and is it soldered in like the caps EW
I am trying to determine what to do with my Mitsubishi ws 65869 TV that went out today while my daughter was watching it. *Does that mean she broke it? JK. When you turn it on the green led turns on (you hear a relay click) then the light goes out after 2-3 seconds. Reading about this TV on another post I ran the diagnostics and it returned at 2-2 error code. (short protect). Is this something I can fix (engineer) or should I call in a specialist? Could you suggest what it would take to get it fixed? < 500.00?
If someone has a service manual for this TV i would greatly appreciate it.
Larry could i get the "Fix it how to kit"? send it to [email protected]
Hi, I signed up for this site in order to get advice on how to repair my Mits WS-55859 problem. I discovered this forum through a google search. I am pretty sure that I have the DM cap problem and was hoping that I could get some help reparing it. A short in a lamp tripped my breaker and now my tv will not power on. I get a constant blinking green light. If someone has a service manual on how to repair the problem I would greatly appreciate it if they could send it to me at [email protected]. Also, just in case the problem is with one of the fuses, please send me that info also. Thanks in advance for any help you can give.
I have gone through all the caps and fuses on my Mitsubishi it all checks out but still the green blinking light of doom I noticed there is a reset button on the exterior of the DM board where it has a plate covering it I also noticed a green light off the board the went off when I pushed the reset button then came on again if you remember this all started after the repairman changed my convergence what do I need to be looking for now Thank You EW
I have a WS-55513 and i of course have the green blink of death. Im trying to find the DM bored is there any way i can have the service manual sent to me or a discription on where the DM bored is.
hello i have a ws-55511 my problem started with the color in the picture acting a little crazy sometimes it is perfect then you have to turn the color way down to get it to look half way decent.but now i have the green lights iwas wandering if these 2 problems coulb be connected some how.if you dont mind i would like the fix for the green lights and the repair manual for this tv idont know where the dm is located.thanks in advance for the [email protected]
Frank, they could be caused by the one problem. Cannot really be sure till you replace the capacitors. I will forward you these documents and the service manual. Good Luck
Can anyone help? I just got a WS-55859 and when I got it home and plugged it in all I have is a blinking green light. I see other people in this forum have replaced caps. So where might one find which ones if not all to replace. Any help would be greatly appreciated.
Just a quick update Larry After going through the entire DM board the repairman and I fiqured out the power board on this Mitsubishi 65" Model #WS 65869 is shot. Since I cannot purchase this board anymore (they do not make it) Go fiqure So I have decided rather than send the board to PTS to rebuild I would cut my losses and get rid of it I would like to know what a reasonable price would be or just take it to the landfil. EW PS The cost would be about $500.00 for rebuild and installation costs Thank you so much for your help
Good morning, Larry. The Model Number is WS-65869. Thanks again.
Thank you so much. I am looking forward to the e-mail. Happy New Year.
Sheljr
Hello Larry
They are on their way again Rick. Good Luck with the repair.
Hi,
Rick
Larry We checked the fuses and found out F9B01 4A is bad What now? Should I replace all the fuses as well . EW
What is the model number of set are you working on? Where is the fuse located?
Rick, the repair information will be sent out a little later this evening. Good Luck.
Where do I get a fuse for that and is it soldered in like the caps EW
Break, look at my answer to your thread please.
Sorry Its late at night Model #WS 65869 Located on DM board
Hi,
Thank you
Hello Larry
Hello Everyone,
AJ
AJ, info is on it's way to you. Good Luck with this repair.
Can you also forward the repair information for my tv too (blinking problem) thanks!
Bill
Bill, what's the model number man. There are three differant fixes. I am NOT a mind reader.
Sorry about that
Mitsubishi WS 65869
Bill, I am sending them out to you this morning. Good Luck with this repair.
Bryan
