1994 Pioneer sdp6081 projection tv bowed pic.
teamelim
The picture is bowed on all sides.  I already changed the stk on the convergence board, what else might be the problem?  Thanks for any and all your help.  And yes I am a new member.
You should have changed both
You should have changed both IC's and there might be a fuse or a circuit protectior that might be bad in the power supply or around the STK IC's.  What was the STK type you changed?
phil85
Larry Dillon said: You should
Larry Dillon said: You should have changed both IC's and there might be a fuse or a circuit protectior that might be bad in the power supply or around the STK IC's.  What was the STK type you changed?
Can you call me at my work ext. I'll give you a toll free number so you do not have to pay for a call.  Its 800-311 5198 my name is George.  Its just easier for me to explain over5 the phone because I may not know what I am talking about.  Please and thank you.
