The problem I am facing with my TV is one that I have seen others here describe too: Standby timer blinks nine times, and no picture or sound.
I did a search on this site for a service manual for my Sony TV KDP51WS550, in vain. If you manage to find one, could you please email it to me at [email protected].
I see you have a lot of satisfied customers here. So, any words of wisdom would also be appreciated. I am not exactly handy with a soldering iron, so I would like to get your recommendations on whether I should look at hiring a tech, and if so, is there someone that you would recommend? Or should I try to mail in a G board(?) to get it repaired? And how much should I look at spending to get this fixed?
My tv is a Sony KP-51WS500. One day it suddenly got double image, about 1 inch up. I have tried to use Flash Focus but that did not solve the problem. Can you please send the service manual to me. Thank you.
I have a Sony kp51ws500 it is about 5 years old, It will go all blue then fade to a balck and shutoff the power light blinks 6 times. anything I can do? Can I get a copy of the service manual please?
I am having convergence issue on my Sony KP-51WS500 Color Rear Projection TV. The red color is displaced to right by about 1".Tried flash focus several times. Did not help. Is it worth getting repaired? What could be the issue? It is 6 1/2 years old. ( Do not have repair estimates). Can a person with limited knowledge handle this kind of reapirs? Thanks.
yes they can this happens to be one of the easy repairs but cannot send to you without an e-mail address, if the pic is clear then yes it will be a lot less to repair then to replace it!!! please include model number and problem with e-mail as since my brain cancer my memory stinks!!!
One day I turned on my TV but then it quickly fades to a white screen- then goes into standby mode. A day later, When you turn the TV on it turns red. Does any one know what this could be. Can I repair it my self. Model# KP-51WS500- HELP! Please!
This is a great site. Kudos to you sir!! My KP-51WS500 recently had the "3D" color effect with the Concave screen appear.
I am going to purchase 2 IC's and some 5A Picos. I found some great prices on Bluestar Intl Corp's website. Have you purchase from them before? are they reputable?
Thanks again for your insight and knowledge.
Rugger
First off, thanks so much for providing this page.
I just inherited a sony kp-51ws500 from a neighbour, since the picture was all screwy. After doing some research this aft, it looks like it's the convergence. The image is really weak though, and all the colours are out of sync.
Found the service manual for the kp-51ws500 in another thread, but before finding this page, I ordered a complete step-by-step repair kit for this convergence issue from tvrepairkits.com - has anyone ever dealt with them? Did I pay way too much for the parts?
My neighbour had also had the back panel of the TV off, and said he'd tried adjusting the sliders on the three light cannons to get the image to line up - do you know if this is something I can put back in order - ie: is there a standard place where each of the three sliders on the RGB projectors should be locked, or will I have to play with it endlessly?
I ordered the ic boards and installed them this morning. Set now works great! If it hadn't been for all the great folks on this thread, I never could have done it! Thanks Again! hope I can get a few more years out of it!
it should if the solder job on the ic's was done properly!!!!
no you did not pay too much for the ic's as i know that company sells only original Sanyo replacement ic's also if you figure out the shipping and handling for all the different parts resistors, picofuses, heat compound and the technical assistance is a bargain at those prices!!!!!!! you need to do this job properly it will add up to over double of what you spend there. also if you have a problem with a repair how much is it worth to have someone who will send you the service manual for free if you ask for it!! and stand by you during the repair??????
I would appreicate your help, like everyone else! I have a KDP-57WS550 and I have a convergence problem with the red off by about an inch. I tried to auto focus, manual focus, reset the tv using the remote, power off reset, sill the same problem. Sounds like it is the STK392-560 ics, I checked the six pico fuses (yellow) on the DS board and they all ohmed out ok, but I coudnt find the pico fuses on the G2 board; I would appreciate it if you could help me out, sounds like you have a little procedure written up to help with this problem, or if you could offer any addiotnal tips, cheap places to buy the orig. parts, etc. I would appreciate it.
Thanks [email protected]
I would like a copy of the service manual for Sony rear projection TV, KDP51WS550. I have the infamous blinking Standby-LED issue (nine blinks), but can't seem to locate the specific manual for that TV model on your website. Also, unsure if the remedy is identical to the one for a slightly different TV model. Am guessing it likely is, but would like to get it confirmed.
Further, is the current recommended remedy to work with partstore-dot-com to get a replacement board, and if so, what is the exact part to replace: D-board or G-board, etc?
D6301 6-500-567-21 DIODE 10ERB20-TB5 or equiv.
D6116 8-719-081-97 DIODE MMDL914T1 or equiv.
Looking from the rear with the rear cover off, the G board is the first board from the left in the row of horizontally mounted boards at the bottom depending on the model of set. The chassis that the boards are mounted on may be withdrawn after removal of three screws that hold it in place. The parts info is as follows. IF the set has a G board most likely you have the bad diodes if you have a timer Light that flashes 9 to 10 times here is a list of common models that uses the diodes. NOTE: There may be other Sony models that use these diodes
Sony KD28DX40U
Can anyone give me advice on my Sony KP57WS500. The colors were off a few days ago and now it it's dead. The tv blinks 3x and then it blinks 6x more times but more quickly.
my email is [email protected]
the manual wont work is it expensive
Thanks a lot.
JN
could you please send the manual to me at
thanks
i could use a KP-43HT20 service guide.
If you would please e-mail me at [email protected]
Can you e-mail me ([email protected]) the service manual for the Sony KP-51WS500. Thanks.
is'not that manual available as a free download in the technicians corner here on techlores resources forum ?
That manual should be on the technicians corner my friend, it is under the resourses tab oin the home page
Can I get a copy of that KP-51ws500 manual I am having convergence issues. thanks [email protected]
Hi Can someone send me the service manual for a kp-51ws500. I tried servicemanuals.com, but that didn't work for me. [email protected]
Much appreciated.
Bill
Rugger
I have a kp 53xbr300 that has no picture. Is it the projector lamp?
My kp 53xbr300 has no picture is it the projector lamp?
Are there any lights on the front of the set flashing???
Will
Hi,
Thanks a lot,
JN
REF. NO. PART NO. DESCRIPTION GENERIC VALUES
Sony KD28DX40U
Sony KLVS23A10
Sony KV-14LT1B
Sony KV24LS35B
Sony KD-32DX40U
Sony KLV-S26A10
Sony KV14LT1E
Sony KV24LS35E
Sony KDLV26XBR1
Sony KLVS32A10
Sony KV14LT1K
Sony KV24LS35U
Sony KDLV32XBR1
Sony KLV-S40A10
Sony KV-14LT1U
Sony KV32XBR400
Sony KDLV40XBR1
Sony KP51WS520
Sony KV21FT2K
Sony KV36XBR400
Sony KDS-50A2000
Sony KV14LM1B
Sony KV21LT1B
Sony KV38DRC1
Sony KDS55A2000
Sony KV14LM1E
Sony KV21LT1E
Sony KV38DRC1C
Sony KDS-60A2000
Sony KP46WT520
Sony KV14LM1K
Sony KP51WS520
Sony KV21LT1K
Sony KP46WT510
Sony SATB55P
Sony KLVS19A10
Sony KV14LM1U
Sony KV21LT1U
Sony VPLVW100
Total Models: 39
Thanks all, had only to replace the convergence ics,
that's a lucky and good thing man??????
Larry
