Here is a unique one for me. I have an RCA RT2500 surround receiver. It has been a while since I have used more than two stereo speakers. Yesterday I hooked up the surround and center speakers to the unit. The unit will NOT recognize the surround or center speakers, and no matter which surround selection I try (ie Pro-Logic, 3 Channel Stereo, etc.) the unit still displays only the two left and right speakers, and again will not recognize the surround speakers or the center speaker. I re-stripped and re-plugged both surround wires and the center speaker wire, and also made sure that there was no excess wire or wires touching. I tested all the speakers with a multimeter and they are all reading 6 ohms as usual. This perplexes me. I unplugged power many times and let it sit one time for over an hour, and still the same thing. I figure I will check here before paying to have it serviced, or, in this case since it is only an RCA, buying a new unit. Any suggestions?
Nevermind guys/gals. Helps when the user figures out how to use the "test/SetUp" button. I forgot to hold it down for 2 seconds to go into the setup, everything is cool now, they need to make these things moron-proof....
