I just purchased a Samsung DLP 50" Projection TV and I am tring to connect it to a yamaha reciever using hdmi cable's I connected my cable box to my yamaha reciever using the rca componet cables...and i am not getting any picture signal.
For every in, there must be an out. So, if you ran a HDMI and component video set to the receiver, then you must run a HDMI and component set out of the receiver and to a seperate input on the TV. To view the appropriate source, you must switch to the apporopriate input on the TV and receiver.
See if that helps get you back on track.
